carborator help?
Ah i see. It is the performer rpm that is only one pattern. My bad.
Yes. The RPM comes in either spread or squarebore, but not dual pattern. They are not for emissions engines because they are not available with EGR. This is SBC only, others are different
It's been a little while since i had a normal intake on my car. :lol:
Normal intakes are kinda boring 🙁
well the quadrajunk fit on there, however if i keep it i will have hood cleance issues. so im not even sure what im gunna do right now
IIRC the holleys are taller than the q-jet, at least mine is. my q-jet does fit with a performer intake and 3in air cleaner and a touch of room to spare. the holley fit with the same air cleaner...barely
A performer intake a quadrajet carb shouldn't be a problem. What kind of air cleaner are you running? If you don't have one already look at getting a drop base air cleaner and maybe a 2" filter element should take care of any clearance issues.
