Re: Chime wont shut off!--Where does this ground go?
Yeah I realized that wire was from something unrelated.
Basically here's where its at. My factory radio was not putting out sound for awhile. Bought a new aftermarket one, decided not to keep it. Left no radio hooked up. After that the chime would be on the entire time the lights are on. Finally figured out a fuse blew. Replaced it and it blew again in 2 minutes. Hooked the old radio back up to see if maybe it was serving as a ground. Drove it tonight for about 35 minutes all was well until I turned onto my street, fuse popped, buzz came back.
That fuse serves the Center gauge cluster(which is out of order, waiting for a friend to help install new printed circuit board), Dash warning lights, VSS, TCC, Trunk release(which I don't have) and rear window defogger(which hasn't been hooked up for awhile, long story).
Its either a huge coincidence that something is having a problem causing this or I messed something up messing with the radio. My fear too that it could be something in the ignition itself. I tried running the car and turning the wheel several times to see if it would pop the fuse from something inside the column and nothing. Im lost. sh*t is aggravating.
