7"How wide is the rim? I have a feeling on my cutlass that extra 1/2 inch of bs would really make things rub under full lock
It would be nice if they offered an 8" or 10" width rim for the rear with 3" backspacing. The factory super stock III's were reported to have 3.5" and I have frame rub with drag radials. I'll have to measure one of my NOS spares.
So youre saying that if I got the 15 x 8 with the 41/2 bs on all 4 corners I should be ok? or even go with a 10 in wide rim in the back?Something is wrong if you are rubbing the frame with 3.5" BS and a 8" or 10" wheel. Even 275's shouldn't rub in a straight line with 3.5" BS on a 7" wheel and 8"/10" would move the tire further from the frame. A 10" wheel with 3.5" BS would put the tire into the outer fender on most G-bodies unless the car is jacked way up in back. 4.5-4.75" should be close to ideal with a 10" wheel.
Most GM factory 15X7's are closer to 3.9/4" BS than 3.5" and that .4" on such a narrow makes a huge difference. T-type Wheels are 3.75" BS and don't rub the frame with 275mm tires. GN wheels are 3.9" BS and do rub the frame with 275mm tires. As the Wheel size gets wider the tire overhang is less so the BS can be increased.
That's just BS ......Your numbers actually make more sense. I've measured them before and thought the actual number was closer to 4" but wasn't sure after reading 3.5" on 442.com I didn't think that a wider rim would bring the side wall in that much. Hmmm, maybe I should try an 8" rim with 4" BS...Most GM factory 15X7's are closer to 3.9/4" BS than 3.5" and that .4" on such a narrow makes a huge difference. As the Wheel size gets wider the tire overhang is less so the BS can be increased.
