Without looking at your car, I can't say for sure, but I will say that it would probably be best to avoid just snipping wires. It can turn into what might look like a hack job and could potentially lead to problems with shorts. On my '83 Cutlass, I didn't need any of the wires from the computer harness, so I fished them all together, snipped the whole bundle near the firewall on the engine side, and then pulled the whole thing out from inside the car and plugged the grommet. You might need some of these wires if you're running AC or CC, I don't know for sure. The ideal if you're not going to remove an entire harness would be to open it up and trace each wire down to determine if you're going to need it, and then remove it as neatly as possible, preferably from it's source connector. As for the oil and temp sensor wires, it's up to you, but I would leave them in case you decide to run them someday. These are almost unnoticeable compared to the CCC mess, and having an unused connector or two sitting on the intake isn't that unusual, even from the factory.
