Okay-here's a solution to the frequent corrosion/partially melted climate control harness from years of use and underhood heat. Generally, the connectors gets corrosion inside of the connector housing and starts a runaway thermal overheating which leads to non functioning or inoperable blower speeds. The factory harness depending on year and options have low pressure AC switch, clutch coil, etc. wiring tied into the harness as well as other wiring but this kit is designed to replace the most affected area-the connectors themselves.
This is a 4-wire male/female connector harness with the correct gauge and color code for replacing the factory stuff-included are brazed HD butt splices and polyolephin heat shrink tubing. The wiring is j1128 spec so it will withstand underhood temps. I'll be adding this to my store site but I thought I'd post it here so you see what you'll get-12" leads from both ends of the connector housings and they are new as well. Internal connections are soldered and I put a generous dab of di-electric grease inside the connector housing before shipping out. Very easy to install-price is $14.99 plus shipping. PM me for details or visit my store site-I should have them up and listed within a day or two.
3-connector housing AC climate control repair harnesses will be available soon as well.
