This is my second Cold Case radiator, and Im noticing that the seams are splitting again. I want to rule out any potential installation or mechanical factors on my end. Here is my set up
Engine: V8 267
Exhaust: 3-inch manifold
Cooling System: Cold Case radiator with a fan setup
Suspension: Recently upgraded, but I drive in Boston, so potholes are a factor
Do you think the radiator seam failures could be caused by road conditions (despite the new suspension), or could it be related to vibrations from the mods? Is there anything I should check in terms of mounting, pressure, or cooling system operation that might contribute to this issue?
Appreciate your insight!
Thanks,
Dez
Engine: V8 267
Thanks,
Dez
