Anyone ever come across a 5sp from a colorado. Would it bolt to an ls? Are they ok or junk. Ill assume I shouldnt be wasting my time but I guess it doesnt hurt to ask,
II assume you are not talking about the Holden Colorado. I found this on another forum.....if it can only handle 225 lbs of torque I wouldn't bother with it
"After a little home work and a LOT of searching i finally found specs on our transmissions. So heres the info i found. BTW AISIN-AI is the main supplier for toyota motor corporation.
The AR-5 is a 5-speed manual transmission manufactured by Aisin. It is designed for longitudinal engine applications and can handle up to 225 ft·lbf (305 N·m) of torque.
They only came behind inline 4 and 5's, not sure what the bellhousing pattern on this is like but suffice it to say not worth the effort with the gearing and torque rating.
