Colum shifter to floor shifter conversion
scarborough
314
67
70
i would like to convert my Colum shifter to a factory floor shifter. the car is a 87 Olds cutlass supreme, the donor column and shifter is out of a 87 salon not sure what the transmission was. the transmission in the cutlass is a th350. if theirs anyone who has personally did this conversion i would appreciate your feed back.
i would like to find the part number for the right metal clips, and bracket that mounts on the transmission oil pan that holds the shifter cable in place for a th350 transmission,
the shifter i have once pulled all the way back, will click three time when pushed forward before it goes into a slot I'm assuming is neutral, and two more clicks pass neutral. so the big question is will a stock shifter work on a th350 transmission?
402990 for the TH350 cable bracket. (402991 is for the TH400 bracket, you don't want that one)
Spring, range select lever cable, (aka - cable clip) for cable yoke (need 2, one on each end) is 470779.
I prefer colum shifters for automatics.
I prefer floor shifters for everything
Reactions: 08Malibu
I like the B&M Quicksilver shifter for automatics. I've had a few of them. I feel like it gives me the control when I want it.
thanks for your feed back, I search part numbers and this is the bracket that came up but no luck on the search for clip. ill keep looking
