How do I hook the floor shift cable to the transmission? Do I have to change the linkage since I am going from a Column shifter? I have everything I need to do this swap I hope. Thanks in advance.
bordercutlass said:Drill a hole through the floor, put in a gromet and attach the cable. As far as the linkage goes, either disconnect it and zip tie the column to the park position inside the engine bay or buy a steering column from a floor shift car.
deebs312 said:I do have the column for a floor shift the question how would I connect the cable to the transmission?
dan2286 said:deebs312 said:I do have the column for a floor shift the question how would I connect the cable to the transmission?
I believe that there is a different bracket for column shift and floor shift on the trans.
