http://www.summitracing.com/parts/CCA-1 ... refilter=1
This is what i was looking at for my olds 350 because I am under the impression that my preload is not really optimal and the pedestal rockers were really kicking my *ss trying to get them even reasonable. I have heard that these kits are built with stock valve springs in mind and now i have Edelbrock aftermarket springs with a Lunati Cam with just over .500 lift. Now I had to redo my intake gaskets because the rubber seals were leaking so when i had it off i snapped a picture of what the lobes looked like after probably 1000 miles. To me the cam lobes wear looked fairly normal, and considering i ****ed up my break in because i screwed up my timing set so the car had a lot of crank time before its first fire up actually went as planned so the assembly lube may have gone to sh*t but who knows. Anyways anybody with knowledge that can pipe in and let me know if these rockers might unleash some extra power (i have a feeling it could really wake up my cam but who knows) and if they are a reliable setup for a driver
