dudeface said:I have 2 1985 salons...............both have no computer, actually they both do NOT even have the passenger side opening kick panel for the computer. my friend has an 85 442, which is computer controlled. I have seen a lot of non computer controlled cutlass in canada, so not all were computer controlled, and seems rather random as to which years were or were not
peace
lildhix said:@billy is this wat you talking about?
http://www.spohn.net/shop/1978-1987-GM- ... omponents/
DoubleV said:dudeface said:I have 2 1985 salons...............both have no computer, actually they both do NOT even have the passenger side opening kick panel for the computer. my friend has an 85 442, which is computer controlled. I have seen a lot of non computer controlled cutlass in canada, so not all were computer controlled, and seems rather random as to which years were or were not
peace
Yeah up there Canada you guys didn't get computers until 86-87 I think, but all of the H/O's and 442's still had them.
Since you're fom Canada can you answer this question for me? Where exactly was the vacuum operated electrical switch for converter lockup mounted? I'm assuming the firewall, but where exactly? Also, which port on the stock carb was this vacuum switch routed to? If possible, pics would be awesome if you can provide them.
Also, there should be a small vacuum delay valve somewhere in line between the vacuum switch and carb. If you have a spare one of those, I might be interested in it since they are disscontinued and I'm getting conflicting reports on what the aftermarket equivalent is.
DoubleV said:Dudeface, thanks for the pics. Yes, that's the vacuum switch I was refering to. I couldn't tell from the pic, but it appears to be routed to the purge port on the carb ( medium sized nipple on front throttle plate of carb )?
Yeah, if you or any other of north can get any of those blue delay valves ( GM # 14020691 ), let me know. If shipping isn't too expensive, I'll take a couple. Never hurts to have a backup ( and make it worth the shipping costs :wink: ).
