Anyone using the Southside Machine adjustable upper control arm ? Any issues in using them ? I’m concerned about using a control arm on the upper with no bump stop but I want the adjustability of this control arm anyone got any input on this
Why would you want to not use the rear center bump stop? Upper control arms have nothing to do with the bump stop (pinion snubber). I'm setting up with QA1adjustables.
I’m sorry I thought I put front in there,I’m talking about the front upper control arm (blaming it on Covid fog)Why would you want to not use the rear center bump stop? Upper control arms have nothing to do with the bump stop (pinion snubber). I'm setting up with QA1adjustables.
i can't speak to those arms per say but that partictular design when your suspension is@full droop(say on a four post lift or stands on the frame)the arms will rest on the frame..Anyone using the South side Machine adjustable upper control arm ? Any issues in using them ? I’m concerned about using a control arm on the upper with no bump stop but I want the adjust-ability of this control arm anyone got any input on this
