Here is what i am working for on my Wagon.
The plate fits right into the groove in the stock shroud.
The fan is a 16+ inch Derale puller that will be mounted to the inside of the plate.
The hole is offset so there are no clearance issues with the waterpump pulley.
The little blue box is where the relay will be mounted.
I mocked it up and hooked up a battery charger to test.
The seal is so good it was hard to pick it up off the floor due to the suction!
On the race car, it has a double unit from an mid 80 GM FWD.
The lower mounts lined right up to exiting holes in the rad support. I did use spacers, old endlink bushings, on the bottom.
The top was drilled and bolted to small brackets. Needed a slight trim too.
I may not have had to do extra work, I am using a larger aftermarket rad in the race, to make it fit if the rad was stock.?
