Coolant leaking from valve cover
I take it to the shop that did the machine work. Sure it's not the hose that crosses but the choke on the carb? Check all the connections for tightness. I had the hose going into that valve leak coolant on my exhaust manifold before.
leak
why not pull the cover and use a radiator pressure tester, no oily mess to deal with.... most engines need bolt sealeant on the head bolts..
good luck!!!..jesse
i figure it out!!!! the valve cover was leaking oil in that one spot and the clamps on my heater control valve was loose and leaking coolant in that same spot. fix both. runs great!!!! thanks everyone for all your help and quick replies. i really appreciate it!!!
