Corvette C5 front brakes - which brake lines fit?
CruizinKev
382
15
OVERSEAS/GERMANY
www.cruizinkev.com
So I got C5 brakes on my Monte project but ain't got the old Monte brakelines anymore. Want to order new stainless braided lines but don't know which ones will fit with the hardlines. What did you guys used with your C5 brake swaps?Should I buy new ones for a corvette c5 or for a Monte?
oh and btw anyone know what hardline fitting connects to the flex brake line?
G-body lines fit.
Just make sure you tighten the banjo bolt down TIGHT. I didn't have mine tight enough and had one leak and drain fluid from the master.
The banjo bolt will need to be for the C5 caliper along with the copper washers.
Check out Skip - LS Customs C5 upgrade post, he has all the info on there.
