Do you know where I can buy the filter in different pressure ratings?jacobdavis1979 said:Correct me if im wrong i don't know much about the LT1 but i do know a little about the LS. I assumed you were going to use an LS corvette filter and when i asked if you had a return less system at the rail that doesn't actually mean a return less system. The corvette filter has a built in regulator so anything above its rated psi gets sent in threw the built in return line on the filter back to the gas tank so even though there is no return line at the rail there is still a return line. No need for a fuel pump controller. Which as far as i know you can buy aftermarket different rated filters from 30 psi to 90 psi. If they still make them.
You can buy aftermarket rails with no return feed or plug the old one if you really wanted too and just run an aftermarket LT1 regulator adjustable.
Or run stock rails with factory regulator and return feed.
No offense im not really sure why a controller would be considered lol
