ok i got the car running it was 180 degrees off
i can get it to idle pretty good playing with the distributor but no matter if i try to advance it a little or retard it a little it back fires after you let off the gas, is it because it only has exhaust manifolds on it right now?
i bought a carb adjust tool but to me it you cant really tell a difference in idle unless you turn it alot in a direction then it just stumbles
someone got any advice on what i should do? i wanna get this beast running good so i can take it to the muffler shop, i drove her around the block but shes loud as hell lol and back fires after you pick up speed (let off gas)
