Cowl Hood Malibu
dp406
8
Brockport
I am looking for a cowl hood 2-3 inch steel I am in the rochester area NY, I know theres a guy in hilton that is a goodmark dealer I think I want to spend aroud 400$ , please send links for cowl hoods reasonable prices please thanks, I know the ones on ebay are about 530 shipped which i feel it a little to much but o well thanks again guys!!
Harwood makes pretty good stuff, but you will still have to do a bit of body work to it to get it to look perfect. I used one on a 84 Camaro once, and it fit well enough, it was just a little wavy in spots which would not do for a black car.
i have a goodmark cowl on my malibu, front corners are a little higher than anything else. if i got hood pins it would be perfect.
There is a trick to that. You just need to apply pressure tp the bottom middle of the hood and the top of the edge, or the center bottom of the front of the hood and both corners simultaneously. This will allow you to mildly tweak a steel body panel and get it aligned. Just be careful as doing it wrong could dent it. I have successfully done it to the doors of my truck to get them to seal better.
