Cutlass and all Gbody upper trunk drip drop offs developed
tobyp
1,708
40
48
Cincinnati, Ohio
take a peek, I think these are pretty nice since they go all the way up the quarter, if you need the extra...good, if not...cut it off. Good manufacturer here.
Re: Cutlass and all Gbody upper trunk drip drop offs develop
Dude, you are on the ball with getting remaned parts built for the Olds crowd. That is awesome.
Toby, have you developed the lower trunk dropoffs (trunk floor to lower quarter panel), and if so, are these generic parts for all G bodies, or are they specific to one division?
Thanks for the props all!
TO answer your question the trunk drop that falls to the quarter is different from Cutlass to Regal, and I would bet Monte as well. When I put a new donor trunk floor into my 442 it was from a Buick, and it had extra material that I just cut to make the correct shape. So to answer your question yes. Could you use a Regal to a cutlass, yes. A cutlass to a regal, no. Monte to either or either to monte I am unsure.
Cant fortget the rest of the lines! Remember that many parts interchange such as the inner wheel houses, fit all. THe trunk drip rail fit all, The trunk floor will fit all, inner and outer rocker panels will fit all, the door shells fit the cutty and regal. So we are looking at that sort of thing as well ya know.
