Cutlass console repair
2
36
Is there anyway to repair the glove box area without buying a new cutlass console looks to me there is no way but I could be wrong
I had a similar issue with my console. I used lock tite plastic epoxy and fiberglass mat. Use duct tape as a backer , drill small holes around the area your filling in. (This will give the patch something to hold on to) cut fiberglass to fit and drench it with epoxy. Use a popsicle stick to work with. Don't try to fill the area with 1 shot. Let it dry and add a 2nd and then a 3rd layer. Take your time and be sure to mask off the area. You can smooth it with a fine file and paint with plastic model paint. Good luck
Reactions: 1bad79 and ed1948
I concur fiber glass epoxy^^^^^^^^ just remember its already broke so you cant make it worse that's always my logic so don't be afraid to try some stuff that's out of the box
Thanks for the info but the car I'm building I spent some bucks to bring it back from the dead so I really want to keep it fresh so if I can't repair I guess I would have to replace
Send me that console (with return shipping)and a c-note and I will have that console better than new for you😉
