thanks alot 88hurst that was very helpful and detailed. im havin a hard time with the fuse block i took both 7mm screws out then loosened the bolt under the hood but i cant seem to get the fusebox out
i left a couple comments on your video. Where are you from. In the vid you said you got the car from St. Louis. If you are from that area I can swing by I give you a hand
