cutlass stance
kendl77
Oct 28, 2009
56
I have a simple question before I take my car to the shop...my suspension is kinda higher in the back
Than in the front and I hate that stance it urks the hell outta me...id like a more balance
Stance...are there any rear absorbers on the marker I could install that could lower the rear a bit with out me having t replace my rear coil springs...my car is a 1981 cutlass supreme...any help would be appreciated
Only way to lower it is to cut the rear coils or buy a new set.........Or throw about 800 lbs of sand in the trunk 😀
You may just need to get new front springs. Mine sat that way as well when i got mine, changed the front springs, evened it out. Oh yeah, i had v6 springs, switched to moog stock springs.
Try these:
http://www.sportsimportsltd.com/cospcoorsp.html
You can pick them up at just about ANY parts store. These will compress your spring and should work depending how low you want it to go.
These (metal adjustable style) can make it higher or lower.
The rubber style is only to give it height
I have the rubber ones in mine as it gives just a little bit of height withour adding stiffness to the ride.
They are cheap and easy to put in. Most guys don't seem to like them and say they cause instability especially if used to make the car higher.
try f-body camaro springs, they lowered the back of mine about 1-1.5"
jatguit said:
Try these:
I would never use those to adjust the height of a spring. If the spring is too tall then change the spring. Don't use some "easy" fix that deforms the springs and will cause to break.
