Yes, it works quite well. No need to remove the spring completely. Just be sure you can get a small cutting tool in the small space without hitting anything else . Then there is the problem of rotating the spring so the cut end winds up in the little gutter that has the drain holes. I use a LARGE crowbar to get between the spring and the control arm and wiggle/bash it over to where it needs to be. Of course you have safety chained the spring in with something, right? To be honest, if you are experimenting and going to be cutting each spring a few times, just remove the lower ball joint nut and lower the control arm. Then you can get at the spring from the bottom with a 3" whiz wheel. It cuts super fast and doesn't overheat the spring. I prepare for that by getting the ball joint nut loose and whacking the steering knuckle with a small sledge hammer. That deforms the knuckle enough to let the ball joint pop loose from spring pressure, but the nut keeps it from getting away from you. Then proceed as before, getting the spring up into the spring tower. Lower the control arm and cut. As you relax the spring to check the height you can just snug the ball joint nut loosely so it comes right off again. When you have it where you want it, do exactly the same to the other side. You can do one at a time by squeezing the other side's spring with the spring compressor tool so the car sits lever while you asses it. Another thing. You must open the top shock mount hole to 3/4" I think, so the spring tool shaft fits through.When you are done and ready to reinstall the shock, guess what? The hole is too big now! The shock comes with rubber biscuits for the top. They have two sides with lips that fit in the hole. One side is the stock size, the other side is 3/4". Check it and see! Here is an example of how crazy this job can be. I had a Pontiac 400 in my '81 Malibu wagon. I used '77 Trans Am 400 springs. The car was pointing at the trees! 3 cuts for a total of 3/4 of a coil put the car where I wanted it, about 2 to 3 inches above stock. Each 1/4 coil dropped the car a LOT!
