Cylinder Heads on 91 TPI 350
crucial118
1,055
51
48
46
MARYLAND, DMV
Wasup guys? I have a 91 TPI setup and was wondering if any heads can go on the TPI setup. Can casting #10088113 fit with these intakes? Do all vortec heads fit with these intakes?
Isn't the 113 heads the Corvette alum head? If so, then yes you can use a stock type base. The vortec heads use a differant bolt pattern. Here's the TPI Vortec base. http://www.summitracing.com/parts/EDL-3817/
Like I said in the other post, it flows no better than a stock base. Spend your money for better heads and port your stock base or get a better flowing stock type base.
