Daimler 5g-tronic
KCP
421
1,004
Bavaria, Germany
Just got struck by a brain fart.......
Has anybody ever put a Daimler 5g-tronic behind a SBC? This transmission is known to be well equipped to handle big torque numbers (about 1000NM) and is widely used behind high powered V8 and V12 engines. Chrysler used that transmission also behind it's Hemi V8's, called NAG1, only pi..ed off Chrysler engineers can come up with a name like that, BTW :barefoot:
Standalone controllers are available from different companies too.
Thinking about ditching the TH350 in my '85 El Camino in order to gain overdrive. 2004R's are impossible to find over here, 700R4's and 4L60's are mostly the 4.3 units and 4-figure for a questionable one. On the other hand, even if I tried I couldn't walk 100yrds without tripping over a cheap 5g-tronic over here, often still with a complete W210/W211 attached to it.
CaliWagon83
1,933
2,139
Orange County, CA
Only issue you might run into is the transmission controller. I'm not sure if these had a standalone controller, or if it was linked to the engine ECU. But yeah, they were used with the Mercedes turbo V-12s for years, and those beasts made up to 738 lb-ft from the factory!
L92 OLDS
2,872
3,050
West Michigan
Has anybody ever put a Daimler 5g-tronic behind a SBC? .
If they're plentiful in EU then it could be a good idea for you if you can solve the mounting issue. In the US, anything German is typically avoided due to reliability and cost issues. Best advice for BMW or Audi owners is to sell before the warranty runs out.
CaliWagon83
1,933
2,139
Orange County, CA
Ironic how different the perceptions are on each side of the pond. German cars in Germany are considered easy and cheap to work on. Total opposite in the U.S. Likewise, I'm sure parts are hard to get over there for American models that were never officially sold there. Although I heard some G-Bodies were homologated and sold in Europe for a few years.
KCP
421
1,004
Bavaria, Germany
Gbodies were in fact officially imported, at least early Malibu and Monte Carlo as well as Cutlass. At that time GM imported most of it's line up to Germany, but only a few dealers would sell and service them. They even built US cars from complete knockdown kits in Switzerland and Benelux.
CaliWagon83
1,933
2,139
Orange County, CA
They probably said, "Was für ein Scheiß!" :LOL:
8,826
7,779
Melville,Saskatchewan
The adapter plate will be the biggest issue. Personally I would dump the sbc and go with a more modern motor, especially if it is a 305. But I hear that is difficult in Germany if it is a classic car. I owned a Dodge Challenger with a Nag 1 for nearly 7 years. A great shifting trans, never gave an ounce of trouble. They have quite a steep first year 3.5 to 3.9 depending on the application, which will help a weak motor. The overdrive isn't great at .83, so gear accordingly.
DRIVEN
8,075
14,536
*CENSORED*
If that's the ratios, they might actually be a good match to the lame-O gears most Gbodys came with.
They're kind of fat in the middle so I'm not sure how tunnel clearance would be but if it fit I'd run one. I replaced a lot of "Chrysler" transmissions over the years but never one of these. They really aren't uncommon here in the states.
Figure out what it takes to make a NAG1 fit a Gbody and you might just be a hero in the community.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
Red Deer, Northern Montana territory
A Nag1 would be a great choice for a stock geared G body. My SRT8 was a paddle shift NAG-1, it was really slick. The gearing in the SRT8 is like 2.92:1 and for a 4600lb car with 475ft/lbs of torque it was a lot of fun. FTI sells a cheap 2400 stall that really wakes it up, add in some AMG blue solenoids for about 550-600hp capacity.
Figure out the controller and you will have a winner.
KCP
421
1,004
Bavaria, Germany
Standalone controllers for this transmissions are already available from different companies for around 1k$.
