You need to read into this
And this
Should have 6ohm on pin 6, lt Blue of the tac. My GP had 2 or 3 and I need over 4.5 for the ecm to see correct current draw and exit lockout mode.
It won't exit lockout mode until the car is going over 30ish
Does the psi harness use the PRNDL selection switch on the trans? There's like 5 and conditions the ecm needs to see before it allows the cruise to unlock.
And this
DBW Cruise control wiring - LS1TECH - Camaro and Firebird Forum Discussion
Conversions & Swaps - DBW Cruise control wiring - What are the requirements to make it work? I am feeding +12 v to the cruise control on switch signal. A +12v momentary signal to the set/coast input. The TCC signal to the PCM is getting +12v until the brake pedal is depressed. But the cruise...
ls1tech.com
