Decode my 78 Malibu
Call Her Bu
110
38
Arlington, TX
Can anyone help me with a link or thread on decoding my plate? I’ve found some but they’re for a 79 El Camino.
9,167
15,346
I can tell you that your color code is 63 (63L/63U), you have a front bench (A52), your interior color code is 62 (62V).
8,198
17,600
78- Model Year
1- Chevy
A- A body
W27- 2-door Malibu coupe
R- Arlington build plant
166924- Fisher body internal serial number (nothing to do with the VIN)
62V- Camel Tan vinyl (Wallaby pattern)
A52- Bench front seat
63L/63U- lower and upper color the same, Camel Tan Metallic
04D- Build scheduled for 4th week (D) of April (04), 1978.
  • Friendly
Ribbedroof
4,904
7,013
Wellston, OK
What are you trying to find out?
Cowl tags only contain info that was pertinent to Fisher Body assembly operations..things like paint color, top color for vinyl tops, seat configuration,. Just stuff that would require specific operations to assemble the body from the cowl back
GM assembly then assembled the completed body to the chassis, which had been assembled in-house, and added the front clip and completed installation and connection of electrical/cooling, etc.
In most cases, these two separate lines were in adjacent buildings, but not always. Some mfrs and carlines trucked completed bodies to final assembly plants from the coachbuilder operation.
Ribbedroof
4,904
7,013
Wellston, OK
W27 would indicate Malibu Classic coupe.(this by default includes Landau cars, as they were only built on Malibu Classic)
T27 would be a base Malibu coupe
Call Her Bu
110
38
Arlington, TX
I just wondered what it all stood for. I looked up the VIN before but noticed the cowl tag was different.
9,167
15,346
1ATxx is the base Malibu, 1AWxx would include the Elky with the Malibu Classic. Never understood why they were only in the Classic level.
Jun 6, 2021
78- Model Year
1- Chevy
A- A body
Can you please tell me where I can get this information?
Thanks
8,198
17,600
Thanks
A lot of it is in my head, but that's because of years of decoding the dang tags. You know what to look for and where to look for it at. GM RPO lists help immensely in doing this.
If you want to get a good start on learning, try here. It's Camaro mostly, but it's still Chevy, so it'll gear you to all that sort of stuff.
Look at both these links. They show it looking the same, but the 2nd link is the one specifically on trim tags.
79 USA 1
1,065
2,039
Cheektowaga, New York
