1982 Regal. Never had problems before and now all of a sudden the delay wipers do not work. It just stays running in high speed no matter what setting I put it at.
any idea what is wrong?
85 Cutlass Brougham said:You made me pull out the factory service manuals! I have a complete set of 1985 manuals, but only a chassis manual for 1982. Before I go any further, do you have the wiper switch on the turn signal stalk or the dash? Also, does your wiper motor have a white plastic thing on it with the washer fluid hoses coming out of it, or is the washer fluid pump in the bottom of the motor with the lines running to it? I will try to give you a reply tomorrow based on your answers to these questions. There are two different styles of G body wiper systems I am aware of, and I only have manuals with troubleshooting guides for one of them.
Jg85350Regal said:Mine are messed up too and I never really addressed the issue. The washer doesn't work and the wipers only work on low and high. If you select a delay setting the wipers just stop wherever they are. Any idea if its a bad motor or switch? is there a delay box in these cars? it sounds like its inside the motor.
Jg85350Regal said:That makes sence I had actually thought about that myself the other day. I guess i'll grab a wiper motor from the junkyard and give that a try. Thanks
