I ordered the wrong oil pan for my SBC 350 Crate engine BUT luckily... they block was made as a replacement and so it has the bump-out on both sides for the Oil tube. The dipstick that I WAS using on the drivers side is now too short because the passenger side does not have the built in tube running down the side of the block into the pan like the drivers side did. I am doing some research and it appears the passenger side option was also available. Where do I get a replacement tube and stick for the passenger side to make it work that is longer than the drivers side??
