DISC BRAKES AND 15" RALLYS??
The one biggest difference between where you work, and on the forum, is that at work people arguably need to read what you wrote to avoid being accused of not doing their own job.
Here, people will just ignore it, give up reading, and not volunteer to help you with their knowledge.
So, double edged sword. I can think of a few who would/will/likely already have. The only one you hurt is yourself so do whatever you please.
It's just like walking loudly into an office meeting, in sweatpants, eating, talking with your mouth full and food falling out. If you're fine with that level courtesy/online ettiquitte.. well enjoy 🤣
SAW 2 DIFF VIDEOS OF REAR SWAPS AND THEY MENTIONED REAR CALIPER MAY HIT REAR FRAME ARCH WHEN DOIN LS1 STYLE REARS DROPPING THE DRUM PLATES AND MOUNTING DISC PLATES WITH INTERNAL E- BRAKE .. SO I KEPT IT IN MIND IF THAT INFO IS WRONG THEN SO BE IT ..
SORRY ABOUT THE CAPS.... BUT NOT REALLY... I KNOW SOME PEOPLE DONT LIKE IT... I GET IT AT WORK TOO... IM NOT YELLING IM BEING VERY CLEAR LOL
I guess I could understand the rear set-up hitting the frame if the rear end width was changed. Did those videos indicate a rear housing change as well as disc swap?
As for the ALL CAPS.... I understand it (both sides). I had people so focused on the CAPS that they would completely ignore the content of my posts/info/questions when I first started on internet forums >20yrs ago. Their sole focus was to point out my social foul. Like 'Pontiac Guy', I print in all caps w/everything I write by hand. I don't do cursive & up until that point in my life everything I 'typed' I did just like I would if writing by hand because I never used a typewriter before using a key board for a computer.
Do what works for you but keep in mind others (as mentioned) will be not so focused on what your needs are vs. theirs (what irritates them).
HAHAHA LETS KEEP THE SMALL D!CK ENERGY TO A MINIMUM ... AKA "CYBER BULLYING" CHATTER IS GOOD AND ALL BUT LETS NOT TRY TO BELITTLE ANYONE .. DAM DID IT AGAIN WITH THE CAPS.........
