Thanks Nick. I found a source that indicates they do NOT go back on. I was wondering this as A. modifying the bushing could cause it to have unnecessary friction and B. The spring will keep the weights down anyways. I decided to not try and modify the bushings, and left the clips off of the weight pins. I did put the clips back over the center plate.Yeah, they mostly do. Your recurve kit should have come with various sizes of bushings but if not you may have to carefully shave down the ones that fit to get them to the correct height. Be very careful when attempting to installl those cute little E-rings, they like to snap back and then go hide. Also make sure you have them in from the correct side as some of them come with shoulders and that flat face has to be between the weight and the base of the pin
NIck
