Hey guys...
What's the easiest way to remove the G-body door panel? I've gotten all of the screws out. All I need to do is remove the window crank and then remove it from the door. Is there a way to do either of these without breaking anything? When working with door panels on my friends CRX, I've been known to break things. Alot. The reason I need to d othis is because the door is all messed up. Doesn't close or open right, and the outside door handle mechanism is screwed up. So I need to buy a 50 cent part to fix it.
:wink:
:wink:
