Do you think you could drop the pan and swap the rod and main bearings from underneath? It wouldn't do anything for wore cam bearings, but should give enough of a bump in pressure to not need 20w-50 oil anymore.Well I put on the new hose for a 70 Cutlass, since that is what the rad came out of. I used a small tail pipe expander and it mostly straightened the nipple. I had to cut 2" off the new Gates lower hose or it kinked, even with the spring inside. Well took the car for a drive there is good and bad. The good, the serpentine belt stayed on and no issues. The transmission is no longer leaking any amount. The coolant leak is fixed. The bad, my cruise didn't work, I should be able to fix it. The car ran around 200+, 210 on the gauge. Assuming the temp gun is right. Plenty hot for a 260, don't think I would consider reinstalling the 350. This cars cooling has always been poor. Also the 15 psi oil pressure with 20w50 oil blows, tired little motor. Also the 18 mpg imperial was dreadful, yes it was over half 10 percent ethanol but 8 mpg less? I even topped up the tire pressure before leaving, if anything overinflated. Also it has taller tires so 150 rpm less. Maybe the headers and 2.5" exhaust killed the mileage? Also I have given up on the A/C as there has to be a bigger leak.
I considered using a good 330 crank I have but this only a temporary motor. Yeah 15 psi at 2000 rpm isn't good. I added a bottle of the Kleenflo motor "honey" now nearly 20 psi, whoopie. I may drain out the coolant and put in fresh stuff. I might have to grind the cradle so I turn the drain c*ck. Other than that drove fine, even passed with ease on the highway. The 260 sounds awful at high rpms, probably some pinging but it loves a massive amount of timing at low rpm. The plugs are nice medium brown but have a tinge of white which might be the colour they are actually firing now since there are only a couple hundred Kilometers on them with the headers.Do you think you could drop the pan and swap the rod and main bearings from underneath? It wouldn't do anything for wore cam bearings, but should give enough of a bump in pressure to not need 20w-50 oil anymore.
