Drilling Cast Iron......
That's right, cast iron carbon nodules act as graphite so you don't need lubricant.
Otherwise as long as it's not induction hardened it usually cuts easy.
Reactions: fleming442
I used the grease to stop the shavings from going into the exhaust manifold on my truck. I still had to use a magnet after it was drilled and tapped to make sure all the shavings were out so they didn't go through the turbo.
When I turn 5x4.75 to 5x5 for guys I use HSS no lube.
I like cast iron, makes a nice chip
Drilled out the pushrod holes in my Vortec heads. Grabbed a bit and went at it dry, had both heads done in a minute or two with zero issues.
Used to do a lot of this. 6 foot radial arm any size hole down to 1/8npt. then chuck the tap in. put it on slow and let it eat.
