I recently did a 305 to 383 motor swap. Everything is good but for some reason my drive shaft is rubbing on the brace under it, Not the cross member that the trans bolts up too but the brace that comes after it. What can i do to eliminate the problem? Also, can i just remove the brace and if it works leave it off? or will that be unsafe? If i remove it will it make the body misalign itself?
