drive shaft too long
creepin cutty
Nov 16, 2006
94
hey, i just put a baddddd ls motor in my 1986 cutlass with a 700r4 transmission and today... i attempted to install a 8.5 GN rear end...i ran into one problem...and i wanted to know if it was typical, my drive shaft is about an inch too long..it was cut once before to fit my stock drive shaft but now i must cut again! just want to know if this is a typical thing when installing a 8.5? Thanks for all your help!!! 🙂 😀
-Frank
Yes, the installation of an 8.5" rear requires the driveshaft to be shortened 1" 8)
yep, that's normal when going from the 7.5 to the 8.5.
damn, you out-typed me.
post some pics of the motor and the car when you're done!
it looks like it'll fit but remember that the cover is a pretty important part of the rear's integrity. and if you're going to be using the car hard you also want the main cap supports.
