Driveline Bang/Clank -Shifting to D
ed1948
1,286
1,613
Quinte West, Ontario
86MCSS, stock drivetrain, 305, 200 4r, 90K miles (I have put on maybe 400 miles total, so, not a lot of seat time)
Shifting into gear causes a sharp lurch and driveshaft/diff noise while keeping brake on. Reverse is good and gentle.
Idle speed is 650 in neutral and near 550 in D. I'm not positive but a warmed up transmission seems to make it worse.
I suspect there may be a problem with the transmission.. It feel like its going to lunch the U joints. .Any
thoughts?
It has done this before I installed the B&M shift kit.
U joints show no slop
but
the rear axles clunk when turning over low curbs(in -out movement axle clunk)
Did some reading on the web and it seems to be the noise is from rear axle gear looseness..
