I drove a 81 Cutlass wagon today with a '72 Pontiac 350 (originally had the 301, so they went the Pontiac route). He's asking $2,000
Here are the strong and weak points as saw them.
pros
*engine swap already done
*TH 350 (although I'd prefer an 200R4)
*reminds me strongly of my first car.
*goes and stops fine
*electric windows appear to work okay
*bench seat in the front (I love that)
*the frame looks really good (like 5 years old and never driven in the snow good).
*no rust in the rear wheel wells (this is a particular weak spot I have noticed)
*paint is pretty good
cons
*Engine not an Olds
*needs upholstery job in short order
*needs a headliner and dome light
*the engine bogs at WOT pretty badly (I think it's probably still got the 2.21 rear gears)
*kind of rattle-ish (I think the frame-body pads are shot)
*The windshield needs to be replaced
*The A/C pump was set aside, and is now either missing, or the bracket is, or both (he said he would look). Getting the air in working order is a must for the family and the missus in particular.
*The engine smells like it is running really rich, which is no big deal, but that coupled with the bogging probably means tuning the carb jets/checking the timing, which I have never done. The carb is a newish Edelbrock.
*The little dash clock and radio are both shot (ehh, so what)
*Most of the weatherstripping needs to be replaced.
*Needs the new rear end ratio and posi.
*Some of the brightwork trim pieces such as the quarter window trim looks to be borderline. This stuff may polish out, but I am not sure.
*the doors seem heavier than I remember them, which I attribute to early power window mechanisms. being so heavy. Speaking of, I am not that confident about working on those.
*The front driver's door hinge was pretty bad, which wasn't a problem on 4 door models as I recall.
*really minimal rust (here in PA, that's a positive -- there are a couple of small wrinkles in the paint at the bottom of one rear quarter, a couple of brown spots at the bottom of a door)
Discussion
1. Let's assume that I take the seats to be recovered in vinyl or maybe fabric like they have now (think family with little kids). How much do you think the bench and the wagon seats are going to run me?
2. What's the availability of replacement headliners? This one needs a Navy-ish color. How much?
3. Air conditioning. Has anybody brought one of these systems back from the dead? The last G body I had was kept in working order. The one prior, I was told I could spend $3,000 and still not have a working system. How about conversion to R134a? Has anybody done that?
4. Let's assume that I have to replace all weatherstripping. What is that going to run me? I have read here that there are some weatherstripping items that are no longer available. Can those be replaced?
5. If for some reason I didn't want to title this as an antique, it would have to pass emissions. Is just adding a Cat going to do that?
6. Have any of you installed an aftermarket cruise control system, or perhaps retrofitted a factory one from the junkyard? What's the experience with this?
If any of you have points you'd like to advise me about, relative to weak points, or areas to be on the lookout for, please let me know.
Thanks.
pros
cons
*Engine not an Olds
Discussion
Thanks.
