I would like to install a custom dual exhaust onto my 1986 regal (GN clone).
I have obtained a pair of Thornton Dual Exhaust Manifolds: http://www.tntmusclecars.com/350jr_exha ... folds.html. I'm planning on running two 2.25" pipes thru a dual input/output cat on the passenger side and finally thru two high flow mufflers.
This issue that comes to mind is the o2 sensor. It currently is installed after the y connection and with the new exhaust I was planning to install the o2 sensor in the dual cat. Will the temp from the dual cat burn out the o2 sensor?
Thanks for any advice.
