3XBrownCutty said:I know I'm a little late on this, but cant you just take the pedal assembley out, and grind the little teeth off the arched part attatched to the pedal, and put it back together? You could slide around in the winter the same way, it'd just take a little getting used to![]()
Are you talking about making it so it does not lock? What would you do if you needed to use it for its intended use?
