I am not sure on the timing curves on the late 307s....
The final thing that can be done (and it saves you any hassle of rewiring anything) is having the ECM reprogrammed. I would consider it a last step if either of the following occur:
1. The timing curve really needs changed (but not the inital timing as that is NOT ECM controlled).
2. You want to be 110% sure you got every last bit of potential out of the new 350.
Finally if you did remove the ECM (and make all the required changes), there are ways to keep your AC. I think it might require some rewiring though.
Whatever you do, share some pictures. I am sure that Olds 350 will leave you looking like this --->![Icon Mrgreen :mrgreen: :mrgreen:](https://cdn-0.gbodyforum.com/oldsmilies/icon_mrgreen.gif)
