edelbrock #1406, edelbrock aluminum manifold?
87 Buick limited
15
33
bay area 650
Hey everyone, I have a edelbrock 1406 carb on a edelbrock aluminum intake manifold I was wondering if it will fit a stock 305 or 307 engine? thanks
It depends on the intake itself. The aftermarket manufacturers like Edlebrock make intake maifolds for a wide varity of engines. Some, like Pontiac, can use the same manifold as almost the rest of the clan, Ponco 326/350 / 400 for example.
Check the intake and find the part number and then check a site like summit or jegs, look up that part number and it should tell you which engines it would work on. I can tell you that the carb is a performer 600 cfm with an electric choke.
it should i had the same setup on my 305 in my old firebird worked pretty good
4 bbl
