El Camino LS swap fuel tank
Through my research, I believe people are using grand national or buick t-type fuel tank and sending unit. They are fairly cheap on rockauto but I'm not sure if the tank is a direct swap or if it's needs to be modified to fit
The grand national tank is completely different than a wagon or El camino. From what I have seen the Buick road master wagon tank is the closest to a direct fit. Also El Camino did have tbi fuel injection just have to use a pump for the higher pressure that the LS/4.8/5.3/6.0 uses.
Reactions: Turbolq4
Your biggest problem will be finding a sending unit for your stock tank
Dixie restoration has the new 4.3 sending units.. I have one pair with a 255 walbor
