Electric Fans
Brandon
Oct 7, 2008
56
Whitby, Ontario, Canada
Hey Guys,
Recently I've added a second electric fan so I'm running 2 Flex-A-lite S-Blades and have noticed a decrease in the speed and power of the fans since adding the second one as well as my ability to blow through a fuse has increased.
The instructions say to use a 20 amp fuse for one but I kept blowing it last year and upgraded to a 30amp with no issue. Just took it for a run and blew the 30amp with my 2 fans.
Here is how my fans are currently wired.
Uploaded with ImageShack.us
Any suggestions or ideas as to my issue with lack of power and fuse blowing? I've checked the line for shorts and couldn't find anything.
the way i see your diagram it will not work correct . my picture shows a basic parallel circuit i would also run 2 relays or one 40 amp relay for both fans and the fans neutral being grounded out to the chassis . use the t-stat on the neutral side of the relay and the 12v side of the relay on key on/off side of fuse block . so in a nut shell the t-stat is your switch turning the fans on and off .if you still not sure i can draw you up one in detail
I was also going to suggest running one relay per fan. Theoretically that should take care of your fuse blowing issue.
So.. jsut to clarify.
I should get a 40 amp fuse, Then connect both my fans directly to the t-stat?
I think I may need that picture
ok ill draw you a picture ...how many amps does each fan draw (load) then i can tell you what relay you need .if it was me i would run 2 relays just in case one fails you still have another circuit working and able to cool the car down .
hows that for you ?.....this drawing is based on a total of 18.4 amps of load . 9.2 amps each as you said befor. if u want 2 relays just split the fans up and run two 20amp relays .i also drew up a over ride if the t-stat fails at any point.always run a relay on any heavy load items you run in the car if you didnt know already.
