Tilt column to non tilt column swap
Aug 22, 2024
2
24
I decided to swap my tilt column in my 78 el Camino to a non tilt out of a 1978 k20 and now it won’t crank I had read the conversation works and it did besides that it won’t crank but also in the time that the column was out I put in a new starter a JEGS mini hitachi style one to give me more clearance with my headers and a new battery because the old one was leaking acid has anyone done a tilt to non tilt swap and if so what could I of messed up. I have 2 connections under the column that I can’t find where they go and I also very well may of wired the starter wrong I am new to all this.
Most people swap a non tilt column for a tilt column and consider it an upgrade being able to find the most comfortable position.
What was the problem with your tilt column to begin with?
The bearings came out and went everywhere inside and then I spent way too long fixing it and just decided that I didn’t like that it had so many failure points.
