Electric Fuel Pump Location
garyb
9
SouthEast Texas
Hey Guys, could you guys post photos of how you have mounted your electric fuel pumps? I am thinking about a Holley blue pump and Mallory filter. I might build a bracket between the gas tank mounting bolts on the front of the tank. I would like to see some examples and also open to suggestions for a good location. Any help is appreciated
Thanks,
Gary B
I know some pumps need to be gravity fed. And most pumps do better as a pusher rather then a puller. So mounting as far back as possible is ideal. Typically they cannot be higher then tank. On mine I have an EFI inline pump which I mounted to the crossmember bolt holes which is the middle of the car and below the tank. Seems to work for well for me.
I should be getting my airtex fuel pump in today and was wondering where to mount it to, can you please post pics, thanks if so
Well I installed mines today, still have to wire it and connect the "in" hose
I hope this is a good location
