I'm wondering if these are hard to come by. I've only run in to 1 car that had them at the scrapper (they're on mine now), but none others, even the ones with power windows in the front.
You would be correct thats why i stated window portion up top is differrent.Longroof79 said:The 4-dr rear doors are the same as the wagon, only that the window frames (and vent windows) are different.
Theoretically, you could use the 4-dr doors on a wagon if you want to remove and reattach the window frames and glass.
The power vents on a wagon are not uncommon. However, they're usually part of the power window package which is more prevalent on later wagons, or cars that were well optioned.
