Today on the way to work I hit a pot hole on the right front side. Now my aftermarket tac wont work and stays below zero and tries to go backwards some. Also my factory voltmeter is reading 8 volts and jumps around going backwards. I checked my alternator and battery and they are fine. Checked connections for the tac as well. The last item to go haywire was the choke light. It came on and wont go off. Checked voltage on that as well and it reads good and the choke is not stuck. So has anyone had this problem. What should I check now. I cant see how these would all be tied together so where should I start. Any ideas welcome.
THanks Guys. :?
THanks Guys. :?
