Electrical problem...
rogus
428
168
sounds like a bad ground or a dead battery are you sure the batt is good did you put a load tester on it ? it;s typical when you turn something else on it draws away the ground from what ever was working like the clock clean the batt cables on the battery and the other end of them
Reactions: rogus
My cable end are clean. I took the battery to be tested and it's good.
