the in line fuse might be blown get a tester to see if is getting power. if not cut it out and see if you have power
454cutlass said:the in line fuse might be blown get a tester to see if is getting power. if not cut it out and see if you have power![]()
86 maroon gp 2+2 said:inline fuse as in the grey connector or the red connector thats got nothing connected to it, sorry I'm just a noob that does not know how to do any of this. Also do you use the ohm or volt scale when checking for power? Probably the volt scale
86 maroon gp 2+2 said:so just about 30 minutes ago I was screwing with the radio while the key was on and it turned on! I think it may be a lose connection now...
